200rwk out of an n/a ecotec?
Discussion in 'Mace Engineering' started by UP THE RED VS, Nov 3, 2013.
  1. UP THE RED VS
    UP THE RED VS Member
    MACKAY, QLD, AUSTRALIA
    VS COMMODORE UTE
    just wondering how possible it is to achieve 200rwk out of an n/a ecotec and what would be need, i have my own ideas but just wondering if anyone has done this before?
  2. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    The first thing you would need is alot of money, and little care that you're spending copious amounts of it to make what essentially a stock LS1 with a $100 exhaust makes.
  3. MACE
    MACE Well-Known Member
    Hi UP THE RED VS,
    Thank you for your enquiry:
    To get a genuine 200rwkw in a NA V6 ecotec on 98 octane fuel isn't an easy task and would require a serious build. To give you an idea we're talking about bumping the rev limit up to around +8k, comp of around 11:1, cam with a duration of around +230, massively ported heads, custom made inlet manifold and probably custom made extractors. Thinking about what I’ve just written will probably make more then 200 however these are some of the things that need to be considered. If you’re planning on using E85 fuel then you’ll definitely be able to get away with a cheaper build, being able to get away with more comp, smaller cam and heads etc. Some of our speedway customers running a standard throttle throttle body and intake manifold on 98 octane fuel have nudged close to the 200rwkw.
    Hope this helps
    If you have any questions please don't hesitate to ask
    Kindest Regards,
    Steve
  4. Pollushon
    Pollushon Boost gives me a bar....
    VY SS
    You spend $5k on a Raptor and forget n/a. 200 rwkw done. Trying to do it n/a, times that figure by two or more.
    If you do it in something like a vn-vs, you have the instant advantage over any ls1, cos they only fit them to boat anchors ;)
  5. benny_bones
    benny_bones New Member
    Rye
    Holden VY Series 2 Wagon
    Convert it to l67
  6. Kiddo
    Kiddo You're serious bro?!
    Mitsubishi Colt
    Anything is possible with the right cash flying around. A 200rwkw ecotec would not be streetable.
  7. HamaTime™
    HamaTime™ VIP Member
    VE SSV G8 & RV6 4Runner
  8. Pollushon
    VY SS
    You mean n/a, cos mine is over that and extremely streetable.
  9. Kiddo
    Mitsubishi Colt
    Well the thread is about N/A applications...so yes that what i was meaning lol
  10. Husky
    Husky Active Member
    Pakenham
    VXII L67 Berlina Wagon and VEIISSV M6 Sportswagon
    COME racing in Victoria claim that their stroked Ecotec is good for 220 kW at the fly wheel so that would be a good start. It's 6500 for the complete engine though. That also include a bullet crank, which are pretty valuable on their own.
    Sent from my C6603 using Tapatalk 2
  11. UP THE RED VS
    VS COMMODORE UTE
    a supercharger might be the go the, so the next question is a l67 swap or bolt one onto the current ecotec?
  12. Husky
    Husky Active Member
    Pakenham
    L67 conversion is probably cheaper. But a bolt on will probably give more grunt. I'm playing to buy an L67 wreck and put that motor in my car as it is more discreet.
  13. Kiddo
    Mitsubishi Colt
    I can claim my penis makes 400ft/lb of torque, but would you pay $6500 for it?
  14. immortality
    immortality Home of the smoky breakfast Bacon! Staff Member
    Sth Auck, NZ
    How many shaft HP is that LMAO :rofl2:
  15. Bowen
    Bowen New Member
    Alstonville
    2002 VX S manual 3.8L SP
    The billet stroker kit is $5000 on its own so as a complete engine man that's not a bad price really... Ported heads n what not as well or is that just the short block?
  16. Bowen
    Bowen New Member
    Alstonville
    Is also good for pretty much whateva u want to throw at it!
  17. AirStrike
    91' VN SS
    Or spend the $5k+ on a LS1 and turbo and make 400rwkw....................but go ahead and be 'different'
  18. TI3VOM
    TI3VOM Active Member
    Here there and everywhere.
    VT Commodore
    Has it started again?
  19. MACE
  20. MACE
    Regardless of engine type, at the end the day if you want a reliable powerful engine internal upgrades will need to be made, which are costly. There are some exceptions to this which come in mind such as some Toyota engines which can reliably pump out much more power then factory.
