2010 caprice factory mags
matt1984
adelaide
2010 Holden Caprice
The rims on the caprice i dont mind.. just want bigger so the car still look sort of stockish just fills the gap a bit more... anyone know where i can get them from? thanks :) ive asked around a few different places but no one seems to know
vongy10
Gunnedah
CV8 Monaro V2
Bigger rims won't fill the gap mate.. They'll make the gap look bigger.
matt1984
adelaide
2010 Holden Caprice
so your saying if i remove the standard ones and put 20's they will look the same space wise...?
ephect
Donating Member
VS Acclaim V6
Yes unless U keep the same tyre profile on the 20s, but that will throw out ur Speedo reading due to the rolling diameter difference.
_R_J_K_
Zenki S14
Go lower instead. Suspension is the only way to fix that gap.
slepar
omg duz it like...dose??
vn ss
I had 22s on my ve calais v8 standard height, it filled the gap heaps and because of the standard springs the ride was still very good.
B-Man
SA
VY 5.7 Calais S2
as said above it wont fill the gap more BUT it will give an optical illusion the gap is smaller as the rim is bigger
will still look that height tho.
matt1984
adelaide
2010 Holden Caprice
yeah see cant go lower cause driveway goes like this /\ lol. straight up and than down lol.
jr_
Donating Member
VE II Sportwagon
Just putting it out there...Calais V S2's 19's - the same as SSV S2's
I also have issues with my drive way so haven't considered lowering my slo-mega wagon so know where you're coming from.
19's might look nicer than stock on your Caprice but not make the gap look too big
The reason I suggested the Cal V's over SSV's is that they don't have the black shadow and the centre caps are silver not black - you might be able to put Caprice centre caps in (just a thought...)
