BadBoy
- Aug 25, 2021
- 4
- 0
- 1
- Age
- 33
- Location
- Darwin
- 2010 Holden VE Commodore V6 Seden
Hi Mates,
I have recently got an error code show up on my scanner - P0989 - Transmission Fluid Pressure Sensor/Switch "E"
My Commy is a 2010 VE automatic and shifts 1st, 2nd gear quite poorly, hesitant with high revs in between. This also happens when shifting out of Reverse and into Drive (harsh/rough shift into Drive)
I suspect perhaps the sensor needs replacing but before I consider taking it into the mechanics, I just thought I'd check if anyone has had a similar experience with this particular error code/situation and if there is a simple solution.
Thanks
Thanks
