I keep getting two errors show up Check engine & contact dealer x service No fault found when scanned, changed battery and still have same issues without any codes Any suggestions?
Has anything been done to the car recently? Battery voltage ok? Has it been load tested? Alternator charging? Have you tried disconnecting the battery for an extended period (like 24H)? Is the stability (ESP) light on too?
One would think it should create a Instrument Panel Error and activate the MIL, as its part of the BCM menu.
