Thats why I said HJ to WB. HJ to HZ is only 5 years, but the ute and panelvan body remained the same for 6.. the WB. Yeah they changed some removable panels, but the actual shell didnt change.
Not sure on the front subframe on HZ. Did they change the actual frame or just the addons?
To me thats what was so cool about Kingswoods. You could get pretty much any part or body panel from any other model and stick it on your own model. Of course, you would have to get a set of panels not just one, but it was easy and cheap. Bolting a WB Ute nose onto a HJ Kingswood ( or vice versa) required both front guards, the nose cone and bonnet. The guards and nose cone didnt even have to be separated, you could remove them as one big piece and bolt them directly to the other car.
Even going from a single headlight front end to a twin, or vice versa, only required replacing the radiator support panel as well, and they were bolted in not welded woohoo
I will always remember turning a HJ Kingswood into a HZ Premier parked in the carpark at the Devils Marbles in NT.
I had found a HZ Premier the day before near Alice Springs, abandoned, windscreen smashed, wheels gone and a conrod through the block. Took me and the mate I was travelling with about an hour to remove the entire nose, radiator support panel and all, and tie it to the camper trailer we were towing and keep going. We even took 2 of the doors, because the window runners were playing up in the doors I had, and the tail lights. Next morning, 2 hours parked in the carpark with tourists buses pulling up, we swapped it all over. I think the tourists took more pix of us than the Devils Marbles
It looked a bit silly for a few months till I painted it, because of course I hadnt been so lucky as to find the right colour..
