Jesterarts
Your freedom ends where mine begins
- Nov 22, 2005
- 3,817
- 105
- 48
- Age
- 38
- Location
- Victoria
- 2010 Nissan X-Trail ST-L
This thread is a bit deja vu, but after selling my trusty 2012 Lapierre DH720, I was on the hunt for a new rig.
Criteria:
- Under 2.5K
- X Large frame
- Good condition
- No older than 2012
- AM Suitable
- 27.5 or bigger wheels
I spotted a Enduro COMP 29er on ebay just outside my budget, and after a quick negotiation it was mine.
I am 99% sure it's a 2013, since that's what it says on the frame and it came with the FOX forks, however the frame colour scheme looks to be 2014. So I'm a bit fuzzy on that.
I found this article: 2013 Specialized Enduro Comp 29 SE - NSMB.com , which suggests is a 2013 Specialized Enduro COMP 29 SE, but aside from that one article I see no more references to a 'SE'
Either way, the previous owner looked after it well, and it's mostly stock aside from the pedals and seat post:
Frame: 2013 Enduro COMP 29er
Rear Shock: FOX Float CTD Evolution w/ AUTOSAG, Climb, Trail, Descend settings and reb adj., 215.9mm x 57.2mm
Fork: 2013 FOX 34 Float CTD Evolution with 150mm travel
Headset: 1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
Stem: Specialized XC Trail, 6061 alloy, 4-bolt, 6-degree rise, 31.8mm1
Rear Mech: SRAM X9 Type 2, 10-speed, mid cage
Front Mech: SRAM X7, 10-speed, S3 direct mount for DMD, bottom pull
Shifters: SRAM X7, 10-speed, trigger, w/MatchMaker clamp
Front Brake: Avid Elixir 5 SL, hydraulic disc, alloy backed organic pads, HS-1 rotor, 200mm
Rear Brake: Avid Elixir 5 SL, hydraulic disc, alloy backed organic pads, HS-1 rotor, 180mm
Rims: Alex Roval 26, alloy disc, 28mm wide, 32h
Tyres: Specialized 'Butcher Control' on the front and 'Purgatory Control' on the back
Seatpost: Reverb Stealth
Pedals: Specialized Bennies
Pictures:
For the time, this will be an awesome machine for Lysterfield and with time I will see what else I can get upto.
On the forseeable 'to do list' are the following;
1. Brakes upgrade. The Elixir 5 just ain't gonna cut it.
2. Depending how things go, stiffer rims.
Aside from that, I am going to clear wrap it asap and going to see about the spaghetti cabling... its...err... 'creative' at the moment.
And best of all, the bike matches my shoes now.
Criteria:
- Under 2.5K
- X Large frame
- Good condition
- AM Suitable
Pictures:
