2013 SV6 Z Series Uneven Suspension
madsportster
Australia
13 SV6 Z Series Alchemy
Hey guys, just noticed the rear driver's side suspension is about 10mm lower than passenger's side. My car has 2700km on it. Noticeable with full or low fuel tank level.
Some forums reckon to expect this in Commodores?
Booked in for 3000km service next Tuesday. Suggestions?
rx2_freak
Smokes, let's go.
Churchill
SSV Z SERIES SPORTWAGON
Take it up with holden during service, tell them your not happy with it and want it fixed. If you plan on lowering it down the track dont worry about it.
madsportster
Australia
Thanks. Will do. Just seeing if anyone else had something similar happen?
CONROD
SOMEWHERE in the land of OZ
VZ SS THUNDER 6.0l 6 Sp
funny you should mention this regarding uneven suspension height, Bloke at work has a VE SV6 ute and it has the same prob, about 7-8mm difference LH-RH. Took it to Holden a few times,in the end they just said that its within Holdens TOLERANCE ALLOWANCE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
madsportster
Australia
Interesting. I'll have a yarn tomorrow.
EnFoRcEr_001
Deano
VE SV6 A5
I have the same issue too but mine is a serious one. Ended up lowering the car to resolve.
jeep pit
adelaide
ve ss ute my10.5
had the same problem
lowered my ute and it is more noticeable now than b4 due to tyre sitting just below guard on drivers side and 12mm higher on the passangers side
I notice it everytime I look at the car :(
EnFoRcEr_001
Deano
VE SV6 A5
Jeep, did you just do springs? I found it was the actual shocks causing it, that's why I had springs and shocks done.
madsportster
Australia
Spoke to Gerald Slaven Holden in Canberra. They say its because the fuel tank is on that side.
