2015 VF SV6 LACK OF POWER (FLAT SPOT)
occtec
SA
2015 VF SV6 MY15
Hey, i just purchased a VF SV6 and i'm concerned regarding the lack of power on acceleration, more like a delay. I purchased it from a Holden Dealer in Adelaide, the car has just over 50k on the clock. I believe going by the service book that this was a rental :-( Murphy Holdings trading as 'Budget'. When you first take of in the car it seems all OK, but from then on it's not until you put your foot down about half way before it responds, like there is a delay after the fact. Travelling down a freeway at 100 if i want to accelerate further when i put my foot down its like there is a flat spot before it responds. I took it into holden service today after a couple of hours i received a call that the car is ready for pickup, when i asked what they found they said that this flat spot is when the auto trans is downshifting and further explained that i must be placing my foot back on the pedal during this shift hence why i'm feeling the delay. I feel like they are feeding me sh*t. The service guy mentioned that the trans will relearn overtime but this can take quite some time. Any feedback would be gratefully appreciated, just a s a heads up i did mention to them that the loan car which was same year but Evoke did not have any delay at all at any speed, you touch the pedal to accelerate and it just went. The service guy didn't have much to say regarding my experience, feeling really stressed out as I've spent over my budget already getting this car. One other annoyance I've found is with the steering wheel feeling loose not until your doing 80k+ that it seems to firm up a little, is this normal? Thanks guys, ive tried to explain as best to my ability as possible, i'm not really mechanically minded but feel that something is not right. Look forward to a more sensible explanation and hopefully a solution, maybe better fuel like the high octane 98 would make some difference??? i don't know.
crew_man
VFII SV6 Reserve Edition Sportwagon
Is it auto or manual?
If it's Auto, the first thing to do is learn how the car likes to be driven, which comes with time. With my SV6 it hates it when I plant the foot quickly, but if i lift my foot up slightly then put it back down lightly it will drop a gear and accelerate very quickly, then I can plant the foot harder and get great results.
With Auto's you need to coerce the gears to change (or do it manually)
panhead
NSW Central Coast
Cars
I don’t know anything about the V6 and its trans but there are other members here that will and hopefully they’ll help you out with some good advice.
If that fails to happen I’d suggest you drop into a local mechanic and ask their advice and see how that relates to what the dealer has told you.
A part from that bit of advice I normally buy cars with manual trans but have had some autos and yes the dealer is correct they do learn to adapt to your driving style and the brand new V8 Calais V I recently owned was slow to react and I had the trans tuned similar to having the engine tuned to improve the speed of the shifts among a few other things and it performed out of sight after that.
greenacc
Searching for the billion
VE Berlina
It's probably been run on e10 a lot and done all kinds of driving. I'd be putting in a bottle of injector cleaner, fill it with 95, clean out throttle body and service oil if necessary and go for a good drive!
Hope it helps.
occtec
SA
2015 VF SV6 MY15
Thanks for your reply, really?? I dont feel like pussy footing around whilst driving my car, just want to jump in and enjoy, lol... Yeah mines an auto, funny thing though the loaner which was an evoke had no problem at all.
occtec
SA
2015 VF SV6 MY15
Hope it helps.
Yeah might give that a shot its likely you are correct being a rental. why put 95 in it though, ive always used 98 find it gives better response
occtec
SA
2015 VF SV6 MY15
Thanks for the feedback, trans tune sounds like the go but is this possible on the SV6, how pricey is it? I guess id go to a trans specialist for this? Thanks again
crew_man
It's not about 'pussy footing', as soon as you figure out how the car likes to be driven it will become second nature and you will be able to drive it a lot quicker. Stamping the go-pedal isn't always the best way to go fast.
Also, as said by panhead make sure that it is all in good service and injectors, fuel system etc. are all clean.
OTR CAI, Engine and trans tunes can be had from Oztrack for around $1300
occtec
SA
2015 VF SV6 MY15
Thanks crew_man, wasn't having a dig at your comment just want to drive it without trying to figure out how it should be driven lol.. I think I'll start of with the basics fuel injector cleaner, better fuel, throttle body clean etc.. All else fails I'll take it to a renowned Trans place in Adelaide and take it from there. Appreciate your feedback, thanks mate ;)
tml678
HSV30 Senator (w/end), '00 Magna, '17 Carnival
Did you notice this issue when you test drove it?
Go to the dealer you bought it from and ask to drive one of their demo SV6's. the evoke you drove as a loaner has a different engine so it's apples and oranges.
If the demo feels ok, ask the service manager to drive yours and the demo one after the other. If it feels as bad as you describe stay on them to do something about it. It's still under new car warranty, so personally I'd be pushing for Holden to fix it before getting a third party mechanic involved.
occtec
SA
2015 VF SV6 MY15
Sounds good in theory, just feel like id be pestering them especially after they already told me that it is what it is, but to be honest i'm pissed. As for their demos they would probably be 2016-2017 is that a good comparison? I presume they are the same motor and trans and yes the car is under new car warranty till feb 2018. I also don't feel like i should be spending a cent on it and they should resolve it. I might brave it out and give them another try, might talk to the salesman that sold it to me, he seemed like a top bloke.
redvxr8clubby
Sunshine Coast QLD
VX Clubsport R8 & VE SS
What about sports mode? I assume similar in the VF to a VE - in the VE just knock the gear lever over to the left and it shifts more responsively. Strange that an Evoke would have better response than an SV6. Always thought my SV6 ran fine on 91. I would put premium in when towing (for the benefit of the doubt), but otherwise I ran 91 most of the time (I had the SV6 for 3.5 years with no problems). I think they go quite well. Always thought the auto in my SV6 wasn't as smooth as it could be. When I traded the SV6 on SS of the same age I thought the SS had smoother changes.
tml678
Mate if there's an issue with the car pump up and stand your ground politely but firmly. Who cares if they think you're 'pestering' them??
You paid good money for the car and they have a statutory responsibility to honour the warranty IF there is an issue with the car.
If you really don't want to go back there, then any Holden dealer can do warranty work. The only thing I'd be getting done through a third party is an examination and a possible diagnosis for you to take to Holden as a bit of ammo. The minute they start doing work, Holden might point the blame at them.
And whatever you do, don't talk to your salesman, why do you think he seemed like such a good bloke at the time? Now he has your money he won't want to know you.
If this was my car, I'd be back there every day until it was fixed. Don't let them fob you off
SuckSqueezeBangBlow
39
Heroin White VF2 SS Wagon
If you remove the -ve from the battery for awhile it might reset the learning table of the tranny.
occtec
SA
2015 VF SV6 MY15
The auto seems to change smooth without doubt, it just seems when im driving along say 60k but then decide to overtake for example when i apply the go pedal it seems to respond a few seconds later it just seems to lag out like a flat spot but when i apply my foot further down it then kicks back and goes but then i feel like im giving it more then i should be especially if all i want is just a slight increase of acceleration. I feel like i have to race around for it to drive like it should, almost like the revs are lower then should be if that makes sense. I have tried sports mode, but it doesnt seem to make much difference, it shifts through the gears quicker but still not as responsive in acceleration as i feel it should be. I have test driven other SV6 from other yards and they didnt have this issue, not sure how i didnt notice this before purchasing it (wife loved the color), lol...
occtec
SA
2015 VF SV6 MY15
Sounds like a plan my friend, thanks for the advice
tml678
greenacc
VE Berlina
That sounds familiar and is a lot like my 9 year old VE. These are built for mum dad and grandpa to drive around the burbs and get good economy, yes even the SV6 models.
If it's got the balls when you give it right foot and better response in sports mode then it sounds like the mechanics of the car are ok and you are just expecting more than what you actually got.
On my VE I I find it goes better if you ease into the loud pedal rather than stomp on it so there is not such a lag while it drops 2 or three gears all at once.
A proper engine and Trans service with quality synthetic fluids should help a bit too it's likely to have the cheapest stuff whoever could find that meets the spec in it currently.
My box came to life when I put synthetic fluid in it and it was about 180000 Ks old at the time...
greenacc
VE Berlina
. why put 95 in it though, ive always used 98 find it gives better response[/QUOTE]
95 cos unless it's tunes for 98 you probably won't notice a difference for the extra $$.
Try 91,95,and 98 and see what goes best. I mostly use 95 that's all;)
