occtec
- Apr 15, 2009
- 309
- 17
- 18
- Location
- SA
- 2015 VF SV6 MY15
Hi guys, well the result is positive and negative. Firstly I had no issues after cleaning throttle body and disconnecting battery for the whole night. Panhead, looks like I've fallen into the lucky group of people, I didn't break the gear set nor did I experience any idle issues. Started car up in the morning and went straight to the servo emptied a bottle of injector cleaner and filled up with 98 octane. One interesting thing I noticed was that after reconnecting the battery my radio stations were intact and the was no prompt for security code only the time/date needed to be adjusted. Is this normal, I only disconnected the negative lead in the end and not both. As for cleaning the throttle body, I gently moved the butterfly plate sprayed some Nulon throttle body cleaner on a clean rag and cleaned out the entire throttle body also using a toothbrush around both pivot points of the plate then pieced it back together. Now for the negative, there is little if any improvement and I've had a gut full. Is there anyway to reset the computer yourself or is going to Holden the only way?
