202 Performance Gear
Dan355
Go THE SS's
Street Legal 355ci VN SS - Daily: VP SS
Item:
50hp Super Powershot Complete Nos Setup with Manifold, 6 spec 350 Holley and K&N Airfilter. Also comes with Crane adjustable timing retard module.
Item Condition: 4 Months old, Near new condition
Reason for Selling: Conrod bearing **** it's self. No 202
Price and Payment Conditions: $800 ono
Extra Info:
As said all new only used for 1 1/2 bottles worth. Cheap bolt on power. Everything you need to run nos on your 202 except Crane Computer to retard timing. All wiring included. Can upgrade hp at limited cost. Every 50hp is approx 25rwkw pending on current engine setup.
Holley was rebuilt 4 months ago with adjusted float level, smaller jets, metering block suited for 6cyl application and valve. No flat spots, Great throttle response. Redline Torker2 Manifold. With receipts and fitting instructions.
Item: 9 Port Yella Terra Head (202 Red)
Item Condition: Rebuilt
Reason for Selling: No 202
Price and Payment Conditions: $400 ono
Extra Info:
Rebuilt by HRE 6 months ago. 10 thou taken off deck. Double valve springs, Refaced valve stems, New seals ect. Standard pressed steel rockers. Receipts. Rebuild and machining cost me $220. Very clean
Item:
Stg 2 Crow Cam with matching lifters & pushrods. Alloy timing gear also included (Not straight cut)
Item Condition:
6 months old. Near new. Should be limited wear. Still in motor.
Price and Payment Conditions: $350 ono
Extra Info:
I think the part number is 35666 or very simular with spec sheet. Push rods are H/D Federal Mogul, Lifters are from Crow. Timing gear is Peter Jackson brand. All receipts included.
Item: Electronic Ignition (From 202 Blue) With 9mm Leads
Item Condition: New Rotor & Cap. Rebuilt and Re-Graphed
Price and Payment Conditions: $100 ono
Extra Info: With receipts, Not sure on Re-Graphed specs but can find out
Item: Polished Timing Cover For 202
Item Condition: Polished, Pretty good i guess
Reason for Selling: Again no 202
Price and Payment Conditions: $20
Extra Info: Looks cool
Item: Sony Head Unit 50watt x 4
Item Condition: Very Good. Still works
Reason for Selling: Already have a deck
Price and Payment Conditions: $180 ono
Extra Info: CDX-CA600X
Contact Details For All Items:
0432493448 Anytime within reason
Daniel
Pics will be posted if required. Head and cam pics wont be available till after the weekend as they are still on motor.
Also have Brand new 202 oil pump and new but used water pump for $15 each
Fischer
VB Commodore
do you have pics of the polished timing cover i'm keen
V-ahhh
SA
VN/VT
are you willing to sell the holley and manifold seperate?
VHSLX3300
VN S Pac VH SL/X
interested also in the timing cover pm us if you dont sell it. il take it for sure. Cheers
