202 timing cover gasket
Baphomet
Tatura VIC
VK 202 sedan
Does anyone how much a 202 timing cover gasket will cost?
the_boozer
no more VK
51
Shitsville Morwell
hilux
$20 at most with the timing case crankseal GASKET SET TIMING COVER HOLDEN 6
the bummer is you need to drop the sump alittle bit as the timing case goes on before the sump or do the dodgie and stick a bit of silicon in the corners near the sump if your doing just the timing case with the engine in.
Baphomet
Tatura VIC
VK 202 sedan
ah ok
the sump needs a new gasket as its bent and will need to be fixed or replaced so it works out ok
