22" pentagons?
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Whitesack07, Mar 13, 2012.
  1. vongy10
    vongy10 Active Member
    Gunnedah
    CV8 Monaro V2
    Alright do you see professional race cars with low profile tyres? Pretty sure they wouldn't use 20 or 25 wall tyres.
  2. Reaper
    Vongy is correct. In order for tires to work correctly you need some amount of sidewall flex to absorb the small undulations of even the smoothest road. Weather it's longitudinal or latitudinal grip, you need some amount of "shock absorbsion" within the sidewalls of the tire. I am not a fan of Top Gear Australia but they did make a very valid point a few years back where they ran the same car (HSV something or other) around their track changing only the tires from 20" to 18" (or 19??). It's on youtube somewhere. The smaller wheel was faster around the track by quite a bit.
    If you look at virtually every racing category in the world where tire grip is important you will find relatively high tire profiles (unless the rules limit it). Like everything it's a compromise. The old 75 series tires were way too much tire wall whilst these days 20 series is not enough. Not to mention a lack of tire with such a low profile that will offer the load rating needed for a Commodore.
    Reaper
  3. DLFHUB666
    DLFHUB666 GIT 'EERRR DONE!!!
    Nhulunbuy NT
    VX SS, PX Ford Ranger XLS Dual cab
    Im pretty sure it was top gear uk testing the vaxhuall vxr8 an they went from a 20" to 22" an the car was faster on the 20".
  4. GlenM
    GlenM New Member
    Merredin
    VY SS Ute
    NEW Top Gear Aus: Ep2 - HSV R8 vs Walkinshaw R8 - YouTube
  5. Reaper
    Might have been - I just seem to remember the little weasel guy with the half arsed beard going on about it. Maybe UK did a similar thing??
    Ahhh - thats the one. Thanks - illustrates my point perfectly :)
    Reaper
  6. scouser king
    scouser king Member
    Rockingham, WA
    06 VE SS
    Here you go.
  7. StoneX
    StoneX New Member
    Hastings
    VE Calais-V 6.0L
    No, you don't. Your first comparison was stupid though :thumbsup:
  8. vongy10
    Gunnedah
    CV8 Monaro V2
    Mate in what way was it stupid? Drag racing needs grip as well, you didn't say anything about handling.
    ^ This was stupid. More rubber, more grip. Common sense.
  9. Reaper
    Stoner - your out of straws. I'd give up whilst you are behind if I were you.
    Actually that's not exactly right either. Within reason, 2 tires that are otherwise identical where one is (say) 205 and the other is 225 will produce exactly the same levels of grip to each other when fitted to the same corner of the same car (not at the same time obviously :bang:). The difference will be the 225 tire will last longer in most cases. For more grip, you need to fit a softer compound which in turn will lower the longevity of a tire. Thus, bigger tire gives you a longer life with a softer compound which in turn gives you more grip. Of course there are limits to this, particularly on wheels that steer.
    Reaper
  10. vongy10
    Gunnedah
    CV8 Monaro V2
    Hmm I was thinking more of circuit and drag racing but i guess you're right. NASCAR do that when they race around a ring right?
  11. Potta9
    Potta9 New Member
    Camden
    Ve r8 , B2600
    lol at this thread. I have also seen replica pentagons in 22" for sale a while ago. they are out there but are replicas only
  12. StoneX
    StoneX New Member
    Hastings
    VE Calais-V 6.0L
    I was agreeing with him :thumbsup:
