230 000k's service
Gympie
VT calais 1999
spark plugs
leads
coolant flush
oil change
fluid check all round
fuel filter
now its got a lil rough idle so anything u can think of will be great :)
madsav
your ass
your ass
did u degrease the engine bay or let any water hit the coil pack? cause that could be the problem
EDGE3
NEWCASTLE
1997 VS COMMODORE,1996 GTS-R COMMODORE
check the coils
VT
you could have a dud lead or spark plug,, Also check you leads are on the right plug.
Brett_jjj
Tamworth NSW
vs commodore
If the new plug leads are carbon core silicon type leads,the carbon core can be broken pretty easliy if the leads are kinked or pulled tightly during their installation, once the carbon core is broken,the lead is stuffed.Id also check for a cracked plug,its easy to crack a plug when removing or installing them.Also was the fuel filter installed around the right way with the arrow pointing toward the engine.
