253 rebuild not starting.
chance23
VT SS Supercharged
Ok, so I got an old red 253 to rego up my vb commodore.
Stripped it down and rebuilt. There was a slight amount of putting on some lifters and can, nothing too bad at all. I polished them up and put them back (I say this as I think it maybe the issue, but let’s continue). Throw it back in, degree cam, line up TDC on compression stroke, line msd dizzy to number one cylinder and everything else is hooked up (I rebuilt the quadrajet and fuel is coming out how it’s supposed to).
Turn over and turns over well but doesn’t even attempt to fire.
Pull plugs and check spark, plugs and wire and coil all working with good spark. Check leads are going to the correct plug about four times (made this mistake before). I’ve also checked the dissy isn’t 180 out.
Check compression. It’s a bit low with only number one really low. I think it’s a cold, fresh engine, that’ll come up. I throw a teaspoon of oil in each cylinder and it does come up a bit but won’t start.
I’ve been moving dissy slightly with each option.
Throw some ‘Start ya Bastard’ in and it sputters a few times but won’t start. Repeat this a couple of times and same result (advance dissy a bit with each try and then back, same result). It almost started with a bit more starter spray than I was using before.
I’ve had the rocker covers off and watched and all rockers moving, although some aren’t moving that much.
I’m thinking the original cam was worn down too much and is now not opening the valves enough. So before I resort to a new cam and lifters, any ideas?
Deuce
Super Stock
'94 VR SS V8
Some lifters may have bleed down a little (hence they look to open valves less) but this shouldn't effect starting.
If it almost goes with SYB spray you must have cam good and timing close.
I'll say pull dissy cap, check your at number 1 on firing stroke (dissy should have a knotch in housing for reference). Put cap back on and recheck firing order
1, 2, 7, 8, 4, 5, 6, 3
Bigfella237
Far South Coast of NSW
More cars than I've got space to park!
Hmm... Where to even start (no pun intended)...
If you see pitting on the cam lobes it usually means you've worn through the case hardening and into the soft casting below, once this happens the cam is toast, it will wear really quickly after that. In a Holden V8 they sometimes wear the lobes completely off the back of the cam.
For the price of a cam and lifters it's not usually worth assembling a new motor with a worn camshaft. But even with a worn-out cam you should still be able to get it running.
Lifter leak-down is likely affecting total valve lift, but they should still give you some valve opening unless you're using some very heavy valve springs (which you may want to remove during cam run-in anyway). Unless the second-hand lifters are full of gunk and stuck in the compressed position?
Do you have oil pressure up on the starter? Holden V8's are notorious for having troubles building oil pressure on an initial start.
Did you actually "degree" the cam or is that just an expression? You need to dial-in a cam on the exhaust stroke using a dial indicator to measure pushrod lift, you also need to know the cam specs, which can be difficult to find unless using a new camshaft.
Or if you just did the old 'count the timing chains links between the dots', are you sure you lined them up on the right side (don't laugh, I've seen them aligned on the wrong side before more than once)...
Andrew
chance23
VT SS Supercharged
Lifted bleed down. Makes sense, I forgot about that.
I dissembled and cleaned all lifters, so none are filled with junk anymore.
I did actually degree the cam with a wheel and an indicator and lined up links on the oil pump side.
Oil pumped was primed through the oil sender hole. Done this before on a couple of other motors and it worked.
I know I should’ve gotten a new cam, but didn’t want to spend the extra on this motor as I’m just messing around with it.
Not going to laugh, I appreciate any advice on this one, I’ve stuffed up a lot of things before. Best way to learn.
Deuce
Super Stock
'94 VR SS V8
Andrew
Your picture shows 8 links dot to dot. Isn't it 9 in the manual?
Deuce
Super Stock
'94 VR SS V8
When you degreed the cam, did you accidentally mix up intake and exhaust on #1? If you timed exh instead of intake that will throw it all out.
chance23
VT SS Supercharged
Nope. I did double check that. Going to wait until lunch, give it a good dose of SYB and see if she comes to life, otherwise I think it’s a new cam and lifters.
EYY
VS Statesman
Cam won't be the cause of no-start. Did you advance the dizzy a little, or did you leave it set to spark at tdc?
Are plugs getting wet? Have you checked for spark?
As above, make sure cam timing is 9 links dot to dot. If you just lined the 2 dots up, cam timing is way off.
Take not here: OIL PUMP WILL NOT PRIME THROUGH SENDER HOLE. Don't attempt to start it until you pull the pump apart and coat the gears with vaseline. Don't pack the pump full - just a coating will do. It's just so that the gears will seal against eachother and the housing and create suction.
gtrboyy
vt ss & lc gtr
Did you soak lifters in oil overnight?
Either timing issue of some sort or lifters no oil/bled out.
Doubt he'll get oil pressure untill it fires up or repacks pump again.
Will still start & run with busted ass cam & lifters,lots of old junkers still do with missing lobes.
Check it's got compression,oil pressure & spark then you'll know where to focus.
chance23
VT SS Supercharged
It fired for a couple of seconds this morning and died. Did it a couple of times. Needed a bit of starting spray to coax it.
There’s oil pressure (well at least from those few seconds). There’s spark. Compression is there, but low. I’d expect that on a cold motor though. Pretty much 65psi across the board except number one which is about 10psi.
Sparks where wet yesterday. I changed them over. Also timing was advanced a bit.
Lifters were soaked for a day.
