255/35/20 on front ?
XLER891
33
Sa
Vf ss wagon
Hi all,
New here not sure if this has been covered but I can’t seem too find it, just wondering if I can fit 255/35/20 (9”) on the front of my vf with standard suspension?
If so what offset would I need and will that tyre fit in the spare location??
Thanks
Mattricho
VF SSV my15
I got a quote the other day for new wheels and the guy thought I wanted 275/30/20 (9”) and said it would fit easily and that I could get a 11” wheel in the back. I can’t remember what the offset was but I think it was 30. If you go to a wheel place ask for HSV GTS spec.
XLER891
33
Sa
Vf ss wagon
Hi Matt richo
Cheers but only considering the front end as I will run the same on all 4 corners for rotating
55ams
brissy
ve sv6 sedan manual
10' WIDE WILL FIT ALL AROUND ON VE VF
I CAN SEE THAT YOUR NOT IN QLD BUT RING STYLISH WHEELS, THEM GUYS ALWAYS HAPPY YO TALK ABOUT SPECS ETC AND WILL BE ABLE TO GIVE YOU THE CORRECT INFO YOU NEED
abuch47
Madelaide
LSS3 YOOTE
Looking at HSVi 8.5" all round with probably some 9" PS4S. Not sure if I'd rather spend at least double on hsv staggered for better grip and ride. Any thoughts?
saroadie
2015 VF SV6 Storm
Thoughts...you really should say tyre sizes in mm not inches. 9 inches = 228.6mm.
panhead
NSW Central Coast
Cars
Staggered just for looks alone.
dimetime
ve calais 6lt
I have 10 rears with 275/30 +41 offset with guards rolled, fronts are 9.5 with 245/35 +27 (to clear brembos) I'd say 9 inch with 245/35 with a offset from +35 to 42 will give it a good looking flush look
Mattricho
VF SSV my15
I always thought rim width was inches and tyre width was mm as in the rim is 8.5” and fits a 245mm tyre
Dylan kingswood
33
Hobart
2011 s2 Ve ss
285 on my rear and 255 on the front on my chariot 275 cleared nice but had to roll the guards for 285
