284 crane cam?
smelty304
VS Calais 5L
looking at putting a lumpy cam in my vs calais v8!
just got extractors!
Btw i want itt lumpy is there any other cam that i can put in with little to no more work to my car??
any help would be appreciated thankyou!.
smelty304
VS Calais 5L
What do you mean by slug?
Slow,
and what could i do ?
stall converter and such?
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
Big cams need compression and revs to work. Stocko 5 litres have little of both. Big cam = strong torque/power at the top end. So what you will be doing is moving the power band up the range, sacrificing bottom end drivability. Your other bottle neck is the intake manifold which strangles the motor at even moderately high revs. So, in a nutshell, you are going to build a slug as Blown posted above.
Reaper
Reaper
So better off going smaller cam ?
Other than the cool "chugga chugga chugger" idle (just wind down your idle speed a tad in the tune to get the same thing), yeah - less is very often more when it comes to camshaft selection for street motors.
Reaper
smelty304
VS Calais 5L
Thanks mate.
im really looking for the sound and some powerr,
Cheers for the help mate
383 hatch
41
Cowes, Phillip Island
As Reaper said, stock EFI 5 litres aren't a very good candidate for a big cam, they just simply won't work together....IMO, unless you're going to do it properly, leave the engine stock otherwise you will more than likely end up going backwards.
http://forums.justcommodores.com.au...126529-stock-304-guide-choosing-camshaft.html
Have a look there, that thread it about cams for stock 5 litres, they won't have the choppy idle like you want but the cam will work with the engine.
smelty304
VS Calais 5L
Thanks for that mate thats been alot of help!
will probably go diff gears instead at this point then maybe work the motor properly!
sporty custom
Banned
54
terang
vx
just put 284 cch cam in my vn v8 cant get it to idle under 2200 any ideas been tyying to adjust air fuel mixture on trottle body but seems to be getting worse
