284 or 286 cam how much?
VZHSV
melbourne s.e suburbs
z
ive got the chance to snap up either a 284 or 286 cam for real cheap
now i know this isnt going to give great power if not F.A
but what can i expect with only a cam and lifters??
setup is
pacemakers into full twin 2.5" zorst / hiflow cats
soon to get 3:45 diff gears
what can i expect from this cam ??
low end?? or top end
5-10 kw gain? or even a loss?
Dan355
Go THE SS's
Street Legal 355ci VN SS - Daily: VP SS
I have a 284 sounds good great mid range power
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
setup is
If the rest of the motor/intake is stock you can expect a 15 (or more) kw loss below 4000 and maybe 5 or 10 above. Those camshafts are too big for an otherwise stock motor.
Reaper
greenfoam
102
VP Executive R-spec
Yep even the 284 is too big for stock compression and the banana manifold, you can do much better if that's going to be the setup and what is real cheap? because the cam itself is never expensive
VZHSV
z
**** that sucks then! if im going backwards then stuff that then...
so what cam out there is even good for stock comp/intake
my neighbour builds motors for a living . he has a vr 355 running a flat 11
. so he asked me if im interested in a cam that he pulled outa a customers 304 since the guy is going to 355.
i gota find out exactly what cam it is i could be wrong . he said its a baby cam so i assumed it be a 284 or even 286 .
Reaper
276 at the absolute most. Even that is a bit big for 8.5:1.
Reaper
VZHSV
z
well spoke to my neighbour just before and confirmed that its a crane 284 cam..
he suggests i deck the heads abit and shave them 40thou or something like that?
and also to use a 3000stally . im getting a price figure of what needs to be done so ill post back on what he recomends and if its worth it or not. cheers ppl
PaRaDoX
Because Racecouch...
Melbourne, Victoria
none
i fitted a 276 to mine, down the drags i picked up .3 of a second but lost considerable time of the 60ft but my 0-60 times improved, getting it past 3000rpm was a real challenge.
i pulled a 2.20 60ft stock just with a tune and zorst
and best i could pull after cam was 2.40+/- 5, id have to dig up my time slips
like everyone else has said, you need a manifold + a higher CR and a stall converter to get you past 2500-3000rpm is REALLY needed to go fast, your better off saving up and doing it all in the one go otherwise your shooting yourself in the foot
cams only cost round $200 for a new custom grind..... but you've gotta add lifters and you may as well do springs/ those weak excuses for valve stem seals (a water balloon ring would seal better)
PaRaDoX
Melbourne, Victoria
none
assuming they havn't been decked before 40thou is a good amount from memory it should land you somewhere between 9:0 and 9.5 (9.3:1 i think)
don't forget a tune as well. the new cam will require different timing / fuel, 3k stallie is good.
the banana's still wont do the motor justice. i think it will still go slower than stock...
my mate had a 284 crane on stock everything, i remember him saying "lancers go faster than me!"
