295 Rears fit?
HJ75Steve
33
Australia
VR Caprice
Probably stupid but genuine question:
Can anyone tell me if this sizing will suit the rear of a non lowered VE sedan?
19 x 10.75 Rear - 295/30/19 Tyres
Offset +35
It’s the offset I’m mostly unsure about.
Any help is appreciated.
Cheers.
MrBags
45
VE SSV Z SERIES
If you compare that size to a standard HSV offering the tyre is about 3/4 of an inch wider but 1/2 an inch less tall. Considering the standard HSV rear offset is 57 I think you may run into some rubbing issues with 22mm more offset even in a non lowered car.
One way to find out for sure though!
_R_J_K_
Zenki S14
Use this in combination with a ruler and measuring tape - www.willtheyfit.com
Have you had your guards rolled?
MrBags
45
VE SSV Z SERIES
That is a handy site! Using his measurements vs standard HSV size rims the outer rim sits nearly 36mm further out. That is a long way!
