3.3 supercharged black motor build
Discussion in 'Straight 6 Development And Modification' started by mikeman101, Aug 10, 2012.
  1. mikeman101
    mikeman101 New Member
    new zealand
    vk
    hi , building a 3.3 12 port black carby motor currently standard apart from a mild cam ... and looking to beef up performance . have heat wrapped extractors ready to go and i was wondering . . can i run a draw through / blow through supercharged carby setup through an efi manifold ? obviously ill have to block the injector holes... has this been done before ? also if it has is anyone kind enough to post some links : ). thanks
    mike
  2. Dayvo
    Dayvo Because i can
    South East,Victoria
    VE SV6 Series 2
  3. Tree cutter
    Tree cutter Tree cutter
    Mt Gambier SA
    VX Calais SuperchargedV6
  4. Trikky
    Trikky Member
    Central Coast
    VF S2 SV6 Manual
    there is no reason why you would not be able to do it as I have seen ecotec motors running straight lpg blow thru with a trubo and they just used welsh plugs to block the injector holes
