Gibbo70
- Sep 26, 2011
- 18
- 1
- 1
- Age
- 54
- Location
- Kemps Creek NSW
- L67 VX
Hi all,
I have an 04 VZ that's giving me grief. It idles ok for a few minutes, then has a cough, then idles ok again (repeats over n over again). It drives like it's only running on 5 cylinders and lacks power badly. Also has 'check powertrain' warning on dash with associated beeping.
Had a scan done, (attachment 1), which led me to sending the ecu, bcm, pim and key to Injectronics in Vic. They sent it back, along with a test ecu, saying they could not find a fault with the original ecu. If the test unit fixed the problem, end of story. If not, send it all back, and they will remanufacture the lot. $580 if problem fixed, $630 if remanufacture is required. Reinstalled all the modules and it still runs up to ****. Had a second scan done, (attachment 2), same issues that showed up first time round.
Thought I'd ask for some advice/help here before boxing all the modules back up and sending them off again.
