RubenA
- Sep 14, 2016
- 6
- 1
- 3
- Age
- 30
- Location
- Melbourne, Vic
- 2005 VZ Executive
Hey guys,
I apologise for the long post in advance! Just trying to give as much info as possible.
I've got a 2005 vz executive that has been having issues with low oil pressure and power loss.
Back story is that over a few months the engine seemed to be loosing power/torque steadily but oil pressure was fine as far as the dash was concerned.
For the past week however the oil pressure would drop as the engine warmed up. It would start fine and then gradually decrease to were a ticking noise would be audible. It seems to be worse when on an incline but happens on level ground as well it just takes longer. Not sure if these two are related but I want to get to the bottom of the oil pressure issue before it causes any more damage than it already has!
I got one of those crappy oil pressure gauges that sit in your car to see what the oil pressure was so take these readings as you will.
When idling cold it sits at 20-24psi at around 600rpm. At 2000rpm it goes to 70-74psi. It then starts to gradually drop until the gauge reads 0-4psi and the ticking is very loud. If I put the car in gear and drive a few meters it goes back up but proceds to drop all the way down again.
What confuses me is that my Gregory's says it should be 138kPa when warm at 2000rpm. 138kPa is roughly 20psi according to google so apparently I'm running that pressure at 600rpm. I'm assuming my logic is flawed at some point there as that doesn't make sense to me.
I know about the sludge problem that the alloytecs have so I'm planning to take of the sump to see if the pick up is blocked. I took the valve covers off a few weeks ago to see if anything had built up and it looked pretty good in there. Nothing but clean looking oil and some slight discolouration in the bottom left.
Any thoughts on what could cause these issues beside a blocked pick up?
Also what should I inspect when the sump has been removed? Either just for the sake of it or for damage that may have been caused.
Just stating the obvious but the engine has the correct amount of oil in it and I'm using Penrite 5w-40 Full synthetic.
Thanks in advance for any help guys.
Ruben A
Ruben A
