Aymen Pedram
- Apr 29, 2019
- 2
- 0
- 1
- Age
- 24
- Location
- Melbourne, Australia
- 2007 SVZ UTE
Car - 2009 Holden VE Ute
Engine - 3.6L SIDI (LLT)
Timing Kit - Cloyes Brand
Kept throwing codes for exhaust side cam fast forward to now, i've replaced the timing chains and idler gears (NOT THE CAM GEARS) Everything goes on nicely, all marks line up not rocket science.
Problem is.. When im all done and i've pulled all the tensioner pins i crank the engine a couple of times by hand and after a few turns i have a look and all the timing marks are no longer aligned??? Is this due to the different ratio's on the idler / cam / crank gears and is it normal or am i just freaking out. i've given it a good 10 turns over and the valves never seem to come in contact with the pistons but i'm just trying to be extra careful. As i turn over the engine all three tensioners seem to pop into their non-tensioned position for a second and then pop back out putting pressure on the chain. Keep in mind i've never actually seen the chain jump a tooth just somehow ends up out of time (and so i think).
Thank you in advance
