Adza
- Nov 27, 2011
- 16
- 1
- 3
- Age
- 47
- Location
- zillmere
- VZ ute
Hi ALL
Ive just done the starter motor on my vz v6 ute. I read Kevwal's post about the removal procedure. Taking the starter motor out didn't require me to take the front left wheel off. It was a basic 15min procedure with old one out and new one in. Yes take heat shield off with the torx 25mm bit with extension. Then use a 11mm ring spanner to undo the 2 bolts that holds the starter in from the top of the left hand side of the car. One bolt is located at 1 o'clock and the other at 6 o'clock. then the starter should come out if you pull it toward the front of the car up and then pull it back towards the firewall to access the clip and 13mm nut. Then reverse the process to put the new one in.
