3.8L VX Randomly turns off going around corners
Sam K
22
VX S S2
I have an 02 VX and I'm having a problem where the car turns off randomly while driving and it's only when turning at traffic lights and roundabouts and the thing is it doesn't happen all the time. I got Advanced Engine Diagnostics software and got these fault codes can anyone tell me if these could cause that to happen?
2000.vx.exec
21
South Australia
2000 VX Executive, 1998 VT Exec 304 manual, 2007 S
I'm having a similar problem but it doesn't only do it when turning
Mookie01
Guest
50
Southport
VS commodore executive series 2
Ha you need to do a full transmission flush , transmission fluid will cause your car to randomly cut out , bet you anything fluids all black , change your transmission fluid also you get shaking coming through steering wheel I bet anything as well
Mookie01
Guest
50
Southport
Every two years you have to replace transmission fluid , I do a full flush every two years using full synthetic fluid , transmission failure is 80% to do with trans fluid , and when coming to traffic lights or slowing down as the original thread described cuts out are symptoms of transmission fluid needing to be replaced , and looking at his diagnostics he needs new trans fluid I bet you a million dollars his transmission fluid is BLACK
2000.vx.exec
21
South Australia
right ill have to do that then, though the engine does have a starting issue too which I thought could be related to it
