3" ally pipe in perth
CAFA_TF
PERTH
Blown VS v6 3.8, 76 LX and VT SS gen3
Im working on a project for a top mounted inter cooler on my vs but i dont know where to get the 3" ally pipe from as i want a 1.5m length and i dont want to be paying some retail tool 40% loading. Im in WA any one who knows where to get it id appreciate the help
CAFA_TF
PERTH
Ok turns out "One steel" is the only local provider of something close enough spec for automotive"that i could find", but not selling direct to the public you must call them and find out your closest suppler. roughly $140 for 6m length in wich you have to purchase the full 6m.....( this is 3" 3mm thick."
just incase anyone else has as much fun as i did going threw every local aluminum foundry and refusing to pay $200 for a u bend at gogear out of 4130 molly
Morton
For external use only
Fairstar the Funship
Go through skips out the back of industrial estates and pick out scraps :p
Rossbx
'96 VS Commodore Equipe Sedan
Try Evilbay...
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
You won't find 3" as such but metric 75mm is readily available. Check out capral aluminum or other aluminum wholesalers/retailers in your area. Also ask around some metal fabricators in your area, especially if they specialize in aluminum. You might get lucky. Any common structural grade would be fine.
Reaper
CAFA_TF
PERTH
Cheers for your responces, one steel ally has done the trick
