EYY
- Mar 6, 2011
- 5,754
- 2,036
- 113
- Location
- Vic
- VS Statesman
A couple of weeks ago I picked up another 304. This one's a roller cam block from a VS S3, so I thought it'd be a waste not to do something with it since it's hard to find roller cam blocks cheap.
I've already started collecting parts for it. Plan is to make it a nice torquey engine suited to daily driving and a little bit of fun. I plan to do ALL work myself, including removal and replacement of pistons and cam bearings. I have access to a lathe and plan to make a tool to fit the cam bearings. I'm not an engine builder or a mechanic, but just like having a crack.
Here's what Ive already found:
Morel tie bar lifters and pushrods (secondhand but new)
JCC flat top pistons and Grant rings (secondhand but new)
Crane compucam 2030
YellaTerra Street Terra bolt on roller rockers (non adjustable)
Total cost so far including cost of the engine and all parts listed above is $950.
Planning to purchase:
Durabond .002 undersize cam bearings
King .001 undersize rod bearings
King STD main bearings
Durapro gasket set with felpro head gaskets
LT1 valve springs
With the smaller chamber of the VT heads and the flat tops, I'll be aiming for compression around 10:1, but will do measurements when I start working on it. Heads will get a general tidy up - I'll clean up the casting dags and blend the bowls. I'll be sticking with the banana manifold and giving that a tidy up with the die grinder too.
I've been quite busy lately (seem to be lucky to get one day off a week), but I'll keep this thread updated with pics as I make progress.
Crane compucam 2030
LT1 valve springs
