Hattm420
- Jan 23, 2018
- 12
- 7
- 3
- Age
- 36
- Location
- Somerville
- Vs s-pac ute v8 304
If the timing is retarded (a lot) it'll run hot, some Gilmer kits have under driven pulleys (all the accessories turn slower) which can cause the engine to run a bit hotter at slow speeds.
Do have have a thermostat fitted? Do you have the little plastic cover fitted over the gap between the radiator and radiator support panel?
Ok so timing is crucial, I'll definately get my mech to check that out and set it right.
I do have a thermo stat installed, I bought a new one and installed and it didn't seem to work so I just installed the old one as I new I worked fine before hand. As for the plastic strip I do have this yes.
My mechanic was telling me I might have done a head gasket. I inspected the radiator and no bubbles, but did realise my resivour or overflow tank was very low on coolant or had almost nothing in there.
Can't thank you enough for the help and reply.
This whole situation is doing my head in.
I will replace the clutch fan and shroud for now And will try get hold of a Ford thermo fan and give that a crack.
I will also be making sure the timing is done proper also.
