304 in v6 vs
BANDIT
hackham
VS 304
gday guys need help just put a 304 in a v6 vs and its not starting.
changed loom motor ecu cranked it dident start then found out about the BCM changed that with key to match
still not starting. if i was to chang the memcal with the vats disabled will the car start? also have power to coil spark at leads fuel pressuer still not starting
yxyx64
nsw
Kia turbo + Holden badge, Chev badge in Texas
good way to start a car is to stand on one foot and wave the opposing arm in the air. Helps if you put a finger in your mouth at the same time.
BANDIT
hackham
VS 304
is there a way to chek that without a spec tool??
yxyx64
nsw
just make sure its your own finger (works better that way). Good luck.
