304 Issues. Jeckle and Hyde
Walkers Bay
40
New Zealand
Vs Commodore
So long yarn short.
I have a 304 in a VS Calais. Nice enough car, strong motor, 140km, HSV chip and knock sensor.
It starts, idles, does everything it should right up til the computer goes into closed loop.
Then it will not power away, splutters under heavy acceleration, you couldn't pass a car f you wanted.
Pop a lead off a sensor, trick it into open loop again and goes great again.
2 completely different motors in the same car.
I've tired...
Fuel pump and regulators (both)
Computer and Memcal
Tested the temp sensor (computer)
Tested TPS
Checked O2, even back probed and drove with it
Timing
Idle sensor, tick.
Changed the intake manifold gaskets.
Vacuum lines, checked and replaced as required.
What else could could it to fall so flat in the closed loop?
Immortality
Staff member
Sth Auck, NZ
Tried changing the O2 sensor?
Immortality
Staff member
Sth Auck, NZ
Where did you get the PCM/tune from? has it been altered?
What does it do if you do a full hard reset (disconnect the battery) so everything is back to running on stock tables?
Walkers Bay
40
New Zealand
Vs Commodore
It's a legit hsv computer with knock boards and sensor etc
I have a stock computer and tune too.
Immortality
Staff member
Sth Auck, NZ
Have you checked for fault codes?
You may need to log the car to see what is happening.
How old are the plugs, leads, rotor/cap and ignition coil?
Walkers Bay
40
New Zealand
Vs Commodore
Its logging a lean O2 sensor
The plugs have been done, the leads tested, the dizzy cap is new.
I'm leaning away from coil and ignition module because of how well it runs in open loop.
