304 manifold change, high idle??
speed__demond
slammed and cammed
vic
forums.justcommodores.com.au
vs statesman 5L
okay so had a vac leak so I changed the manifold gaskets,
car drives okay a little rough, but not too bad.
..but when in park or neutral it idles at about 1800, could this be from the manifold cleaner I sprayed out the tb with? or do I have another problem??
I was gunna see what it does in a few days but I thought someone might know better...
immortality
Staff member
Sth Auck, NZ
Sounds like it still has a vac leak.
You may possibly have damaged either the TPS or the IAC stepper motor spraying in the carb cleaner. A stuffed IAC stepper could cause a high idle.
mr j-man
GC
VH SL/E 355
When I used Tb/carby cleaner on my old 5.0 it was idling through the roof, had to pull the sensors and give em a light clean and eventually it settled down after a highway drive and some wot's
