skippy73
- Feb 5, 2013
- 67
- 5
- 8
- Location
- townsville
- vt 5.0 ltr
I have a vt 304 which is Miss firing While Accelerating an surging when sitting at speed.
When it first started I replaced spark plugs with a one mil gap sparkplug leads, then the alternator cable burnt out replaced the cable. Then noticed the distributor was burnt out in one of the plug holes. replaced the distributor cap replace the rotor button Check the timing in diagnostic mode set a 10°and it still has a miss the only code that’s coming up now is 22 TPS sensor Have a check for vacuum leaks can’t find any, checking the wiring for tps now.. . Anyone have any thoughts
