EYY
- Mar 6, 2011
- 5,754
- 2,036
- 113
- Location
- Vic
- VS Statesman
That cable's probably been fitted incorrectly - they don't really stretch. Since it's a conversion it's hard to say what the previous owner's done to get the cable to fit. You should be able to get full throttle - so that's probably part of your problem. What's been done at the firewall? Does the cable still have the rubber grommet/spacer around the end at the firewall?
And yeah gtrboy's right - push the button in on the TV cable and pull the outter cable away from the throttlebody. Then turn the throttle to WOT by hand, and you'll see the TV cable ratchet. Leave the cable wherever it ends up. You can generally move it one click either way without ill effect from this position though if you're wanting to adjust driveability/shift harshness.
