Simba355
all
After many hours of messing around with my car I'm about ready to give up.
The car was running on 8cyl but under load on the road it would starve itself of fuel just going around the block.well I assume it was starvation of fuel.
Have put the following in it.
new injectors
injector clips
Fuel hose
Walbro pump
fuel filter
Plugs
Leads
Distributor cap
Iac
Have spark and injector pulse
Swapped out the ECU and memcal
ECU was swapped out orig because one injector wire earthed out and cooked the ECU.
3,5 and 7 dont seem to be firring although have injector pulse and spark.
Head gaskets?where to go to from here?
Any ideas guys?
new injectors
injector clips
Fuel hose
Walbro pump
fuel filter
Plugs
Leads
Distributor cap
Iac
Any ideas guys?
