MasterOfReality
Miners go deeper
- Feb 26, 2004
- 874
- 1,076
- 93
- Age
- 44
- Location
- All over
- 2019 LC Sahara TTDV8, 1991 VP Calais V8
Hi guys,
Have a VP Calais I'm slowly trying to get back on the road. It has been in storage since 2008 (started and driven around the block maybe 5 times since 2008). It has 151,000 km on it.
It has this issue on cold starts where it cranks for a while, fires then is pretty rough/uneven for about a minute. Its like a really lazy start. It eventually settles down and smooths out but if I give it a rev, it doesn't return to idle and just stalls. Restart it, and it fires up straight away like it should, and behaves perfectly. Idles perfect, no stalling, stumbling, hesitation etc.
I have given it a service. Replaced fuel filter and the muck that fell out of it was brown. Rusty tank?
Going back through my service records to see whats been done and when:
Does this sound like a fuel pressure issue? The fuel pump is pretty new (well replaced in 2008 but only 12,000 km on it) but could have the rubbish I found in the filter stuffed the pump?
Thanks!
- Fuel injectors cleaned 104,000 km.
- Ignition leads (Topgun 8 mm) 104,000 km.
- Oxygen sensor 120,000 km.
- Spark plugs (NGK-BPR6EF) 131,000 km. I pulled these the other day and they looked good.
- Fuel pump 139,000 km.
Thanks!
