96VS355
- Feb 1, 2009
- 8
- 0
- 0
- VS SS
Wondering if anyone has any ideas,
I've had my 1996 304 rebuilt as a 355, and I've found it's developed intermittent pinging. On a cold morning it doesn't make a noise, but once it's been running a while, or on a warmer day, you can almost predict it when you step on it. It's round 10-10.5:1 comp with flat tops, Scat stroker kit, mild cam, runs 98 pump, slightly colder NGK plugs, Starr modified bananas with 90mm TB and K&N pod, chipped, thru T5 and 3.45:1 diff.
Now I'm presuming a lot of this is heat related, although the standard temp gauge is still sitting in the same place it was when it was a 304 motor. The block had a minimal rebore and the heads were ported, so I guess that makes the chambers a little closer to the water, plus the extra surface area of a longer stroke length. It has the standard radiator and thermostat, and the old standard cooling fan, and from experience with other 304's I've owned in the past, that normally only operates when the motor's dead cold or when the viscous fluid heats to a point. Now the fan's spending a lot more time on, and hence loading the engine and sapping its power, and possibly also helping it ping. A couple of times also, it's really dropped off in power when it's started to ping, so I assume that the knock sensor's doing its job.
When does it ping? Cam comes on around 2600, and if I go from a light/medium throttle to heavy round then or just after, it'll usually let out a ping or 2, also if I quickly pick the next gear, it has sometimes pinged again the instant my right foot goes down again. It originally ran 320bhp and about 660Nm. Since then my dyno guy's pulled timing out under heavier throttle and higher sensed temp. It did reduce the ping a bit, but it's still there.. and I've lost a few hp and quite a few Nm in the detuning.
It does burn a bit of oil, say about a litre in 2000 kms - which some say is normal for modified engines and about 3 or 4 of the plugs end up with oil making their way up the threads from within the chamber.
Anyone else had this kind of problem with a 355 or stroker in general? Have I given enough info here to be of help? Whilst I get the principles behind how a motor operates, I'm not a mechanic. My wallet wishes I was however.
