355 stroker
Heeey!!
34
VR Clubsport
hi guys,
just wondering if anyone could help me with deciding on a few things...
i have a 308 5L stroked to 355 with raised compression 9.75:1 forgies, ported heads with bigger intake valves, roller rockers stock ratio, double row timing set in a vr commodore,
just wanting to know what size fuel injectors would be a good upgrade (cc) and what pump would be good, is it worth getting a dual throttle manifold and what else would you recon would be worth doing to the engine to get great power keeping it naturally aspirated.
cheers
Boonz
Donating Member
berri, south australia
green 355 VG ute
very similar configuration to mine.... im running 28lb cream tops,super 6 fuel pump with a torque power dual plane manifold and 4 barrel throttle body
what cam do you ahve?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Also, just to be pedantic, you had a 304, not a 308.....
Heeey!!
34
VR Clubsport
i actually dn't hav the engine yet and it will be in pieces for me to put together in 2 days, the cam so far is to suit the kit but im gna change it to suit the tune to get best results....
oh i thought it was a 308, is that vs onwards?
Boonz
Donating Member
green 355 VG ute
if your lookin at forced induction then it might be worth looking at a boost friendly cam and a group A style manifold because it is easier,cheaper and neater to setup for similar power gains
Heeey!!
34
VR Clubsport
nah wanna keep n/a but thanx for the suggestion.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Is the engine running out of fuel now where ever it is? I'd go a cam upgrade as well as injectors and pump.
When Holden changed to the black motor they were all 304's from there. VK on.
v8_bomberdore
37
goldcoast
vp 5L
i think multi point magna injectors should be ok with what u have a and a walbro intank pump should be heaps, i would definetly go the torque power manifold with the 1000cfm throttle body and if u want have your air cleaner just sticking out the bonnet looks tuff as
Heeey!!
34
VR Clubsport
isnt 9.75:1 comp a lil raised... whats wrong with forgies?
i'll look into that manifold and injectors thanx.
