ScottyDot
- Jan 22, 2006
- 9
- 0
- 1
- Age
- 38
- 96' Series II HSV Clubsport
Hi,
My Clubby stopped in the driveway the other day.... realised the fuel pump wasn't running. It's an in tank Walbro 255ltr/min. Ended up changing the oil pressure switch. Now after 2-3 seconds of the key being turned to the on position the fuel pump runs constantly and she winds and won't fire. It's not until a pull the EFI relay that the pump will stop. Fuses all okay. Fuel pump relay getting power. If I bridge the fuel pump relay though it doesn't make the pump work??
Put the old oil pressure switch in - back to no fuel pump at all.
I assume I have a wiring problem on the OEM side - hoping not the ECM.
Has anyone had this problem before? What did you find?
