Dr HaxZaw
so i just installed a new motherboard (Gigabyte P67A-UD3-B3) and new processor (3.4GHz i7) with 8Gb of ram as well. Also running a Gigabyte HD6870 and a 500W power supply although it says on the side its max output would be 600W (dunno which one is how its rated)... computer was running fine but then after playing a few games of starcraft 2 it shut down and then kept doing it more and more regularly
I've found that it shuts down when it gets to over 50 degrees (not sure how far over but its under 60 degrees). I've tried playing with the fan and all to keep it cooler but i dont seem to be able to get the CPU fan to go over about 1900rpm... anyone have any idea if this temp would usually cause this?? i had an old dual core that used to run in the high 60's without a problem
Also are there any "aftermarket" cooling options that would help?
