4L ford to 3.8L vs
timmysvs
casino
97 vs executive
ive bein told that 4L ford injectors and throtle body fit onto my ecotec v6, dose this work, or are thay full of it? if so what injectors and throtle body would suit my v6?
acarmody
Donati..Whoa Green
VX Berlina
??????? Why?
I'm not sure of the flow rate of the ford injectors, but if its different than the car will require a re-tune. And does the TB have a TPS and IAC that are able to be hooked up to the VS harness? And will the cables hook up too? I'm thinking not.
timmysvs
casino
97 vs executive
what injectors and throtle body would suit my vs then, looking for a little bit more power, nothing to overboard, was thinking vs ss gear?
Blakvsexec
5.0L VS EXECUTIVE
Just changing the injectors anf throttle body wont give you any noticeable difference, you usually only change injectors when your engine needs more fuel like when you put a cam in or increase the engine capacity.
If you want more power, i suggest you look at the mace website and look at their range of plenum spacers, ported throttlebodies, and the like.
Do a search on here about the parts you might like from mace and you'll find an abundabce of info about the effects of each part and what you can do to get the most out of the mods.
Just remember if you change things too dramatically you'll need a retune or your car will run like ****.
