4l60-e questions
sleepa
Shiny...
2010 VE SS Sportwagon, Audi A4, Combo work hack
Kind of have an auto gearbox issue in my LS1 VX. I know it's the 4l60-e, but just wondering if all the auto's from VR were the same, coz if I can get one from a VS or VT then that would be a bit cheaper and easier for me.
Also are the V8 gearboxes different from the V6's? And will a 5L V8 auto fit behind the 5.7?
wogstyler
nth qld
VX Acclaim sc L67
The aut behind your ls1 is a 4l65e which is basicly a beefed up version of the 4l60e.
and no a vr auto is th700. Not the same
kniever
40
greensy, melb
VY II Calais L67 & VN II Calais T5 5ltr
the th700 and the 4l60-e are the same box, its just they used to be called the th700 but changed the name, from what ive read the 4l60-e started from vr and they still use it in the ve
to the op, you need to get a 4l65e as said above
sleepa
Shiny...
hmmm, I thought it had the 4l60-e, I didn't think they brought the 4l65 in till a few years after. But a 4l65-e would be better anyway if I can get one.
kniever
40
greensy, melb
yeh sorry buddy you would be right, this write up is from another forum. i wonder if you can bolt a 4l65-e straight up to an ls1?
Hydra-Matic 4L60-E (M30) /4L65-E (M32) Transmission
Type: Four speed rear-wheel-drive, electronically controlled, automatic overdrive transmission with torque converter clutch
Engine range: 2.8L - 5.7L (M30) & 6L (M32)
Maximum engine torque:
360lb-ft (488 Nm) (M30) & 400 lb-ft (542 Nm) (M32)
Maximum gearbox torque:
610lb-ft (827 Nm) (M30) & 670 lb-ft (910 Nm) (M32)
Gear ratios:
First: 3.06
Second: 1.63
Third: 1
Fourth: 0.7
Reverse: 2.29
Maximum shift speed (M30):
1-2 6100 rpm
2-3 6100 rpm
3-4 6100 rpm
Maximum shift speed (M32):
1-2 6400 rpm
2-3 6200 rpm
3-4 5600 rpm
Maximum validated gross vehicle weight: up to 8600 lb (3900 kg)
7-position quadrant: P, R, N, OD, D, 2, 1
Case material: Die cast aluminum
Shift pattern: (2) two-way on/off solenoids
Shift quality: Variable bleed solenoid
Torque Converter Clutch: Pulse width modulated solenoid control
Converter size: 245, 258, 280, 300mm (M30) or 300 mm (M32)
Fluid type: DEXRON III
Transmission Weight: wet: 74 kg (M30) or wet: 88.3 kg (M32)
Bottom Pan Removal: 7.9L 245-mm converter or 10.8L 300-mm converter
Pressure taps available: Line Pressure
Assembly Sites: Toledo, Ohio, Romulus, Michigan , Ramos Arizpe, Mexico
chargedvx6
VY SII HBD Calais L67
VX came out with a 4L60E. You will need a V8 version and preferably from a VT series 2 (5L and 5.7L have a different bell housing bolt pattern).
Also a T700 and a 4L60E are not directly interchangable so don't even bother wasting your time on that one lol
sleepa
Shiny...
So you can't fit a 5L gearbox to a 5.7L. Are the V6's actually weaker or have different specs or gear ratios, or will the bolt holes just not line up?
Will a 4l65-e bolt straight up to the VX LS1, and if so what exactly did they come in and where do I get one?
acarmody
Donati..Whoa Green
VX Berlina
V6 4L60E has different input shaft and different bell-housing.
sleepa
Shiny...
Thanks guys, so my only choice is a 4L60-e from a 5.7L V8, or (perhaps) a 4L65-e, Anyone know if they bolt straight up in a VX?
sly_gen3
vic
vt acclaim gen 3
An auto from the vt ls1 will fit into vx vy etc and vise versa.
