4L60E auto lunges forward on cold starts
petern64
60
Branxton NSW
vz ss 6lt , 2017 Mustang GT , 2021 BT50 SP
Like the title says , my VZ SS auto sometimes lunges forward on cold starts, anybody have the same thing happen or know what my auto
is telling me , thanks in advance
petern64
60
Branxton NSW
ATF is still reddish in colour, level is at the low side of indicator on cold idle, when driving it's shifting firmly ,not clunking or slipping and the auto is quiet , the car has not been thrashed , it's been about 50K's since I've had it serviced, any advise would be appreciated
Skylarking
123
Downunder
Commodore Motorsport Edition
When you say it was serviced 50k’s ago, what do you mean?
Just a pan flush as some do isn’t a full service in my book. A pan flush only changes some of the fluid since the torque converter isnt drained and often the pan isn’t even dropped and the magnet isn’t cleaned...
Are you certain the correct fluid was put in last service? Have you topped it up at any time since service? Did you use the correct fluid to top it up?
H
harrop.senator
Guest
Yeah , get it serviced and re asses the situation lol.
50k is when I have mine serviced , it's low on fluid and playing up. Take it to a trusty trans shop. Have them test drive it. They'll tell you whether they think a service is worth it or to top it up and wait.
shane_3800
35
places
vr commo
It sounds like it's applying a bit of clutch or band. Could be a sticky solenoid or something.
Immortality
Staff member
Sth Auck, NZ
Start by checking the fluid level with the transmission up to temperature on level ground.
EYY
VS Statesman
Lunging? You’ll need to describe a little more clearly.
Very harsh engagement from Park/neutral to drive or reverse?
petern64
60
Branxton NSW
I will recheck fluid level hot , and it's not doing a harsh engagement , occasionally on cold starts the car wants move forward for a second, it will also make a bit of a clunking sound, does anyone know a good auto trans shop in the Rutherford to Singleton area
H
harrop.senator
Guest
Could be cold start revs are that high it's trying to drive it? Does it at what 1100 rpm?
