5.0 vs ls
Trelos304
Horsley
Vt ss
Sorry if this has been covered before just need a bit of advice, ive got a vt ss series 1 that has tremendous sentimental value to me and I'll probably never get rid of it. So im at a cross road and i dont know whether I should keep it a 5 litre ( either revamp the motor ive got or buy a built one) orrrrr drop an ls motor in. Any advice would be much appreciated.
lowandslow
NSW
V2 III Monaro
Keep it a 5-0. LS are a dime a dozen and don't sound anywhere near as good.
Rebuild it into a 355 for extra noise.
Trelos304
Horsley
Vt ss
You're definetly not wrong just worries anout the amount of cash required to get the power out of the old 5L5cLompared to ls motors
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Dropping an LS motor in will cost you more, a lot of extra stuff will be needed to do the job.
figjam
Donating Member
Far Kurnell
FJ
^^ Yep, and why, and what sort of power are you after.
This is my seat of the pants evaluation ….the 5.0 has more useable torque in normal driving than a LS. If you like to rev it out go the LS. The sound of a 5.0 is better than a LS. Fuel consumption about the same. Rear main seals are the weak point for a 5.0.
5.0 is rebuild, plug and play. LS will be stuff around getting it to work, I'm sure that many have done it, and there are kits, but......
You SS came with the 5.0 which may be a plus down the track, for your sentimentality and a collector viewpoint.
Keep it as is.
VS 5.0
Another vote from me for retaining the 5 litre.
My VE is nice to drive and certainly has more power than my old VS, but it doesn't have the same low down feel, fun factor and sounds that the 5 litre had.
Trelos304
Horsley
Vt ss
Think I've got my answer, thanks everyone for your inputs
Immortality
Staff member
Sth Auck, NZ
It would be cheaper to by a VT with factory LS than to swap yours. My vote is to keep the 5.0 as well.
figjam
Donating Member
Far Kurnell
FJ
Forgot to add in previous post.. The 5.0 has Bathurst 1000 bragging rights. the LS doesn't.
