5.0l engine freshen up
mr_clubby96
vs clubsport
hey guys got a vs 5.0l
im thinking of going just for sum basic mods
cam
stronger valve springs n push rods
also engine vrs full gasket kit
machine the heads
stronger head gasket
top end gaskets
double row timing chain
crazy.vr
VR Commodore
So what is the question? Is there any reason why you are changing all those engine components?
mr_clubby96
vs clubsport
yes there is ive got a leak coming from the rear main seal
so i thought while i got the engine out
il do it properly
Pub247
Melbourne S.E.
Ford Fairmont
For starters VRS gasket set is a valve regrind gasket set and is basically just your top end gaskets including head gaskets.
What you'll need is a full gasket set which includes all gaskets and seals.
i'd consider throwing a cam in and make it worth your while if your doing the timing chain and shaving the heads
clubby_you
brisbane
vs clubsport
dude its a 5.0l if you put a new rear main seal in it is still going to leak...they leaked from new
