5.0L into a VX SS replacing the LS
Tones82
42
Gold coast
VT SS 5.0L & VS UTE 355 5SPD
Hi all just seeking some
Clarification, I have a brand new built 355 from Pavtek that I’ve tweaked a little along with a built T350 from a previous build that got canned due to personal reasons. Can I swap this into a VX SS and replace the LS? Basic setup listed below
Pavtech built 355
Harrop Hi rise
FAST quad throttle body
Haltech ECU
MSD ignition system
Upgraded fuel system - injectors, Holley Billet pumps x2
Vortech V1 T-Trim upgraded centrifugal blower
Intercooler
Built T350
Spec’ed and built by Neil @ Precise Automatics
PWR cooling system, twin thermos with custom sealed shroud
Surge tank
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
Not if you plan on driving it on the road legally.
Bigfella237
Far South Coast of NSW
More cars than I've got space to park!
Since the Holden engine was never an option for the VX you would need to get an engineer's certificate, which will probably cost better than a grand, and that's only if you could pass the emissions test, which I highly doubt you would with that setup?
Probably not what you want to hear but I'd say your best option may be to sell what you have and put the money you get plus the money you'd save into the LS1?
Way less hassles!
Andrew
EYY
VS Statesman
It’s not going to be legal whichever car you put it in, so if it doesn’t bother you go ahead with it. Just need a vt s1 k frame and you’ll need to sort the wiring out on the body loom side so that the Bcm/dash gets the info it needs and can control what it needs to control.
Probably better off looking into an older Holden to put it in though in terms of hassle and cost
lowandslow
NSW
V2 III Monaro
I want a VU SS with a 5.0 for a daily purely for sound and the VU looks but the law doesn't agree with me. :(
Tones82
42
Gold coast
Way less hassles!
Andrew
Because I’ve got this setup already mate and not going to lose money selling it. Also not interested in LS, I love the Aussie 5.0L. Would’ve preferred something more compatible over the VX SS but circumstances aren’t right and the VX is the only option at the moment. If it won’t work I’ll just keep the setup on the shelf for a bit longer.
Tones82
42
Gold coast
Why won’t it be legal regardless what car? Have seen many setups getting around running similar with rego.
EYY
VS Statesman
Because it’ll never meet emissions requirements and the physical fitment will require certification because of crossmember and tailshaft modifications etc.
Remove the hirise and fit a banana manifold without the charger and you might pass inspection in vn-vs. No clear cut answers though - all depends on who does the roadworthy cert and whether the traffic authority needs to see it.
Just because somethings registered doesn’t mean it’s legally allowed to be.
