5.7 litre water problem
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by DV8WHCAPRICE, Dec 5, 2018.
  1. DV8WHCAPRICE
    DV8WHCAPRICE New Member
    Tahmoor
    VH Caprice and VS Caprice
    Hi my WH Caprice sometime has water overflow as if car is boiling. This is an intermittent problem which if I restart the car and let it idle a couple of minutes it won’t do it again when I turn off.
    The car does not run hot and It tows a caravan regularly.
    Any suggestions would be appreciated. My thoughts on this is it could be a faulty cap?
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7
    My guess would be faulty surge tank cap also.
  3. vr304
    vr304 Well-Known Member
    Auckland, New Zealand
    2007 ssv manual
    Wouldn’t hurt to just replace the cap they are cheap enough
  4. corhijasna
    corhijasna Member
    Portland Victoria
    Ifthe cap has failed it will also be sucking the top radiator hose in when cooling down
  5. Brysha89
    Brysha89 Member
    Melton,Victoria
    WH Statesman Gen 3 5.7 ls1 V8, 1997 VT Calais SV6
    could also be a blocked Water pipe in the head (not to sure on their names but its where the water goes to the heads) my WH was blocked never over heated but when car turned off it dumped out of the overflow bottle eventually wrecking my seal in the overflow cap and replaced the cap twice be for i found the problem so get it inspected by a micro cam to see if its that be for its too late.
