5.7L top end on a 5L botton end??
QWK-11E
40
Liverpool
VE SV6 2009
hey guys
just wondering if a 5.7L top end would fit on a 5L bottom end??
any help would b great.
cheers
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
hey guys
cheers
by 5.7 I assume Holden 5.7 (stroker by HSV)
NOT Chev 5.7
if so..yes it will
QWK-11E
40
Liverpool
VE SV6 2009
well the top end is from a vx clubby so i guess its a chev motor.
in that case it wont fit?
sir355
Father Figure
Cairns
VR SENATOR 215, HZ ute
Thats right. The only difference from a 5.7 stroker top end and a 5l top end is the injectors..
RVN 355
37
WEST SUBS
91 VN SS 355
Stroked 5.7L used in the 215i Commodores GTS,Senators and gts r hsv's
Blocks are honed,set main bearings,tuned cam,ported heads,blueprinted block,3 angle cut valves,8.85 compression.
All GTS/Senator VS were Manual T56 with 165rwkw stock
GTS used Larger Brakes,Hydratrack diff.
sir355
Father Figure
Cairns
ah no subdue they were not, sorry mate.
I have to disagree with you on that as i have seen the internals of my engine when it got pulled apart.
All 215's, senator and gts got the hydratrak and t56 yes( senator was optioned with auto)
but the rest is wrong.
geardys
GEARDY
39
Tasmania
95 v8 ute 5sp
Also the VR/VS strokers had 8.5:1 comp but as u said subdue the VT's had 8.8:1 compression
Ported heads didn't happen but the inlet manifold was modified for extra flow and the heads them self incorporated new exhaust valves and seats, dampers and springs.
also a new timing chain and damper that only the 5.7's got.
blueprinted block was an option from the Vs upwards.
RVN 355
37
WEST SUBS
91 VN SS 355
ok it is something i read on a hsv /gts forum or mag i knew about.
Sounds like we all know a bit about the not so common 5.7L Cast Iron 215i
sir355
Father Figure
Cairns
yes we do. Wasn't havin a dig bro, just pointing ya in the right direction.
We can all help each other out. I've started to become a bit of a guru with the work i have had done on the senator.
The 215 should have been a much better engine. The bearings are s*#t, the heads should have been worked on a bit, and the intake should have been twin ttb or something alot better..
Still a good base to start a project though!!
