5l cometic headgaskets
Discussion in 'V8 Development and Modification' started by eaton v8, Aug 20, 2008.
  1. eaton v8
    eaton v8 my little sleeper
    gladstone qld
    vz 6l auto 239cam 3.9diff
    Dose anyone have any idea as to where you can buy cometic headgaskets for the 304 i know the 308 shop do but is there anywhere else ???? has anyone got them or used them???
  2. VKV6
    VKV6 New Member
    VK Commodore
    rocket idustries has them so anyone that deals with rocket or i think you can buy from rocket phone no.02-88251900
    p/no's
    CMH2138SP1027S HOLDEN 308 V8 4.060" BORE .027" THICK
    CMH2138SP1040S HOLDEN 308 V8 4.060" BORE .040" THICK
    CMH2138SP4027S HOLDEN 308 V8 4.035" BORE .027" THICK
    CMH2139SP1040S HOLDEN 308 V8 4.200" BORE .040" THICK
    hope this helps you out and yes i use them they are a good head gasket
  3. eaton v8
    gladstone qld
    thanks mate
  4. eaton v8
    gladstone qld
    i just found out serco import them ph 0738233833 it just cost me $317 for the pair deliverd to my door overnight
  5. vp_304
    vp_304 Member
    **** $317 i thought they were only somewere in the $200 range
    They beter be good for 300 bux
  6. eaton v8
    gladstone qld
    everywhere i rang they were 150 a side i was hoping in the 200 range my self i could have gone copper but the 308 shop said you then have to o ring the blok to get a f**k up free fitment and you have to retension them apprently a lot of people dont do this and have problems i carnt comment as i am only new to playing with boost i can only go on their word i hate doing things twice and they recomended useing these
  7. vp_304
    vp_304 Member
    fair enough
    i heard the cometics are beter than copper for boosted aplications
  8. eaton v8
    gladstone qld
    i ll tell you how it goes i should get them on next week end fingers crossed they turned up today :D and so did the rego renewal:mad:
  9. SilverVH
    SilverVH Banned
    You can o-ring the heads rather than the block, thats a crock of ****. The only problem with copper is seepage from the water galleries but this can be corrected by using a sealant. The problem as such isn't lying with headgasket choice, but rather the inability for the head to be held down to the block properly during times of increased cylinder pressure. I've used an MLS O-ring gasket which cost $95 a side. Combined with some ARP head studs and keeping the rpm to a safe level, there shouldn't be any drama's with blowing out gaskets unless it is from error in tuning.
    O-ringing on the holden motor is good for when the heads lift off the block as it keeps the cylinder sealed to an extent which gives it less chance of blowing.
  10. eaton v8
    gladstone qld
    how much to oring the heads im gessing that is machine work???
  11. SilverVH
    SilverVH Banned
    Any head machinist can o-ring your heads. It should cost around $250-300, then purchasing of gaskets on top of that. If you are aiming for around the 300rwkw mark, then using ARP studs with a MLS will be adequete, as has been proven in the past.
  12. eaton v8
    gladstone qld
    so its cheaper to use the cometic???? i see what you are saying with the oring thats handy to know. the blok i have sitting in the shed is oringed on the blok but im saving that for early next year when i build a stroker.
