5L RPM vs time graph
Jayme
Woodburn, NSW
VL 5L inj
Hi, I was wondering if some others could post up their RPM vs time graphs, im seeing mine get pretty jagged once I hit 3rd gear, I just want to compare it to some others engines.
the attached graph is from a drag run @ willowbank, time was 15.077
and slightly off topic, the here is the air filter I pulled out of the car 2 days later.
88GreenVN
Next Exit Left
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
The jaggerd bits look like it could be pingging.... Only because I seen it maked on another graph a few days ago.
Jayme
Woodburn, NSW
VL 5L inj
take efilive data (or similar) export to csv, open it in excel 2007, then highlight all the rpm points you want to map and click insert > line graph.
you could also take a screenshot of the graph in your logging program if it has charting built in.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
need to buy or build an ALDL cable need a laptop and efilive V4 software or similar.and a pc with microsoft excell.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
should have a vs v8 file in it allready
