jon_vs
- Feb 14, 2008
- 23
- 0
- 1
- VS Caprice
My 5L V8 Caprice drives well, starts without problem. However, while driving sometimes the engine just stops - the engine warning light comes on followed by the rest of the dash lights. I wait about 15 to 20 seconds or sometimes more, turn on the ignition - I hear the fuel pump prime and most often it starts (sometimes it needs a second crank) - idles normally, runs normally so off we go again. I may not have the problem again until the next time I use the car.
I have checked the error codes and only get "12" – telling me that everything is OK. Within the past 50,000 klms, I have replaced the coil, ignition control unit, hall sensor, leads, distributor cap, fuel pump - all this was to chase and fix an earlier problem (the hall sensor). The problem is intermittent but it is becoming more regular.
The car always starts from cold and hot. When I had the previous problems with the Hall Sensor it was (always) more of a starting problem than a running problem.
