5L VN ignition upgrade can it be done is it worth it
Cossack1977
45
got a 5L vn which is still going strong.
Im looking at changing the coil, plugs and leads on next service.
Is there a better ignition setup that i can install. Looking at spending up to $400
Will it be worth it.
RVN 355
WEST SUBS
91 VN SS 355
Bosch Super 4 Plugs or NGK Irridium
TOP GUN LEADS 8.8mm Leads
$180.00
Check out crane cams,msd igniton for new products
AirStrike
91' VN SS
This is what I have:
*MSD leads - $150 aprox
*MSD Blaster 3 coil - $90
*New dizzy cap and button - $25 aprox
*Bosch Super 4's - $100 aprox
This is about as far as you can take the ignition system unless you run an aftermarket controller like a DIS-4, etc.
AirStrike :air:
HNST304
VQ 5.0l Statesman
you can advance the timing as well.
